vcWaitSignalStatement
Wait Signal statement waits for signal to be triggered with a value that matches a given condition or until an optional timeout is reached.
| Component | vcComponent | RW | Gets or sets the component that owns the signal. None means the parent component of the statement. |
| Condition | String | RW | Gets or sets a condition expression that the signal's value has to pass. Leave empty to accept any value. |
| Signal | vcBehavior | RW | Gets or sets the signal behavior to listen for. |
| TimedOutVariableName | String | RW | Gets or sets the name of a process variable where to store a Boolean value whether the timeout was reached or not. Can be empty. |
| Timeout | Real | RW | Gets or sets a maximum amount of simulation time in seconds to wait for a value that matches the condition. 0 means no time limit. |
| ValueOutputVariableName | String | RW | Gets or sets the name of a process variable where to store the signal value that passed the condition. Can be empty. |
| WaitTrigger | Boolean | RW | Gets or sets a value which determines whether to always wait for a new signal value. When False, also considers the current value of the signal when this statement's execution starts. |
